I have a large data block describing a machine setup containing 10 arrays each 1000 elements long, they are a mix of INT, REAL and BOOL. I want to keep data records in a recipe for different machine setups. So I created 10 appropriate tags each with 1000 elements and added them to a recipe.
In in the standard recipe handler I can see that all the arrays have been added to the recipe, but all the values are zero, even though I can see in Step 7 that many are non-zero. What's more, if I create an I/O field to show just 1 element from the arrays, it shows zero, even though I know its not.
What am I doing wrong?
Thanks in advance for your help!
