WinCC Flexible store location for Recipes
userxyz
May 2002
any
2,768
Hello,
On an MP377 we made a recipe screen. All recipes are stored in DB's. A recipe is called by number. This number is used to call the right DB. The name of the recipe comes from a text list (WinCC Flex), the tag is also teh recipenumber.
They can call recipes, make changes, ...
But they cannot make a new recipe. We can make some reserve DB's, but the name of the recipe has to be entered in WinCC Flex...
This is not a flexible way to modify/delete/add recipes (name). The great advantage of having the recipes in DB's is that the MP377 locally can modify/delete/add recipes, and other panels/PC's on the network can do this as well.
If we want to use the recipething in WinCC Flex, then the store location should be somewhere on the network. This is okay for me, but what if the stored files cannot be reached for some reason...
Can the recipething in flexible be made secure... the recipes stored on the MP377 but also elsewhere, read from files by script ? etc... ?
Why not have a db of string array and use the recipe number to point to the recipe name?
Create a page on the HMI that you can edit the name and move it into the correct slot based on its number for edit purposes.
It would have been better to have coded the recipe name into each recipe db imho
cheers
hmm
This sounds good... I'll try this.
Thanks !!
cheers
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
315
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
119
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
766
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,614
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,490
