WinCC Flexible RT. How to adjust "info-text" window ?
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,342
Hi all.
I have looked everywhere, but cannot find where such things as fonts, sizes, colors and standard location is adjusted for the info-text window. You know the additional window you can call up with the HELP button.
What I really would like to modify is a hideous pale yellow background color that is somehow set for this window.
Any ideas ?
(WinCC Flexible 2008 SP2 and/or SP3).
Color and font is taken from Windows Tooltip settings.
Depending if you're using XP, Vista or 7, it differs where you can modify it.
Not sure one can change it on a WinCE panel though.
Don't have one to play with atm.
Thanks a lot Jeebs.
You were right about the color of the tooltip being the same as the info-text background color (Siemens, why ???!!).
I can't get the font to change though.
And is there no way to adjust the size or position of the window ?
I'm not sure where that is changed.
I've searched for it a while back and couldn't find anywhere to change it.
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
304
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
118
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
765
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,607
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,488
