WinCC flexible visibility property
Werner
Apr 2005
IJsselstein
336
Hi There!
In WinCC flexible I want to show objects dynamiccally with the visibility property of the objects.
I want the objects to be visible if RowNr <= MaxRowNr
I use a faceplate which I use 25 times, I only want to show Faceplate 1 to MaxRow to the operator. So by chaning tag MaxRowNr all faceplates with RowNr above MaxRowNr should not be visible.
I could make 25 bits with 25 comparators but I was wandering if there is a simpler way to do this. (What if there were 100 faceplates or objects....)
Sadly, I haven't found a way of doing this; a faceplate instance does not include its own visibility property. The only way I've found of controlling faceplate visibility is to link the visibility property of each object on the faceplate together and then to an external property. If you find a better way, I'd like to know.
Nick
Dear Manglemender,
Thanks for youre reply. I think we hit another (stupid) limitation in the WinCC flexible software.
Hi I have a large number of screens with buttons (menu screens) and i would like 'spare' buttons to be hidden. Is there a way to do this with...
1,935
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
311
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
119
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
766
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,611
