WinCC flexible vs GE Versamax Micro 64 PLC
lufego
Mar 2003
Medellin
I need to communicate a WinCC Flexible Runtime with a Versamax Micro 64 PLC + ethernet module. This module support protocols SRTP and Modbus TCP (server).
How can I configure WinCC Flexible Runtime in order to be able to communicate.
Also, I need to install a Siemens HMI like an alternative station linked with GE Versamax Micro 64 PLC. Is that possible?
Thanks in advanced
WinCC Flexible supports Modbus TCP directly.
WinCC Flexible RT can be an OPC client, so if there is an OPC Server for the Versamax PLC, then that is also a possibility.
An OPC Server that gives access to the PLC tags, in stead of fixed memory area like with Modbus, may be the better solution.
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
288
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
114
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
762
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,587
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,483
