wincc flexible with allen bradly micrologix 1400
What do you want to know ?
With "SCADA" I guess you mean WinCC Flexible PC RT. If so you need an RS232 COM port on the PC.
If you mean a panel such as OP277, you must use the IF1B port with RS422. You need a converter to convert to RS232 for the ML1400.
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
268
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
109
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
757
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,580
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,477
