Wincc Flexible
munir
Mar 2012
Karachi
21
hi guys,
i have a runtime file with .fwx extension, i am using wincc flexible2008 sp2 i just want to open it using the runtime but the problem is an error occurs "the data format of the configuration file xyz.fwx is in compatilbe recompile the config. file"
can any one help me with this keeping in mind i dont have the prg backup only a runtime was provided from manufacturer side
i am new using winncc flex every help will be appreciated
Hello Munir!!
You can try to make a backup of your HMI using SIMATIC ProSave. Now you can stay safe with the backup. It is also simpler to handle this.
Please try and revert.
Regards,
Rajesh
Hello Jesper!
Am sorry, I am mistaken. I suppose, WINCC flexible is a SCADA software especially for Simatic HMIs and the run time file is like an exe. Please clarify.
Thanks,
Rajesh
thx for all the replies just want to mention that i dont have the program backup just a runtime file with fwx format and a pwl file actually theres a problem in panel pc and i want to use its runtime file on my pc
thx jasper i saw the version it was win cc 2007 but the flexible software which i am using is flexible 2008 sp2 is there any way that 2007 runtime file can be opened on 2008 sp2 without recompiling
thxx Mike,
the problem is are there any different functions of 2007 which i need to consider before purchasing the license
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
324
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
121
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
767
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,617
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,496
