WinCC - multiple monitors project problem
Lesa
Sep 2006
Novi Sad
71
Hello,
I need to reconfigure an old project that works on single monitor to work on 4 monitors.
Need to make something like picture 1.
Every screen has menu picture, alarm control and main picture.
Original start picture size is 1280*1024.
Now I make new start picture with size 2560 * 2048.
When I activate project I got something like upload picture2.
I'm testing this at my home, primary monitor is laptop 1280*800 secondary is 1280*1024.
Best Regards
P.S. WinCC 6.0 SP4.
Hello,
I am not sure that I understand what you want to do but this is the only thing that makes sense to me... you want to have 4 different screens from the same WinCC project on 4 different monitors, operational in the runtime?
If this is the case I think that you must use WinCC Client-Server option but for this you also need 4 stations (PCs 1 server and 3 clients) and additional software package.
You can read more about it here:
https://a248.e.akamai.net/cache.automation.siemens.com/dnl/zM3MjQ5AAAA_1143029_HB/Cliser_e.pdf
Regards
I want to have 4 different screens from same WinCC project on 4 different monitors connected to one PC with video card thats supports 4 monitors.
I tried to make one main screen resolution 2xone_monitor_resolution*2xone_monitor_resolution. It is a matrix 2x2 screens.
When I desing that main screen with those picture windows and go to RunTime i got that mess like on picture 2.
Can you see picture 1 that I upload?
That's main screen with 8 picture windows. In run time those pictures dont stand like I made them in Graphis desinger. They mess up, like you can see on picture2 that I upload.
Thanks for replay.
Best Regards
Hey - check out my start picture ;)
Project is for 3 displays.
Start.pdl is a start picture - WYBOR is the most left, wybor_p is the middle, wybor_p_p is the most right one.
Start contains Wybor,Wybor_p,Wybor_p_p.
In wybor... are included final process pictures.
Hope i can help
Hi! The problem: A client of mine want to controll his factory from computers (a few) It's all good and we have WinCC Flexible 2008 Advanced to...
11,111
Hello everyone, is it possible to run several parameter sets of a parameter set type automatically - one after the other with an individual time...
461
Hello dear experts! I use WinCC Advanced Runtime V15 as a HMI for the process. I grab values from AB Micro 850 PLC via Modbus TCP. On the HMI...
2,407
Hi! Let's say I have a production line that logs the PPM and display it as a trend. If I would like this trend to display one trendline per...
1,705
I have two questions regarding the "simple object" switch in WinCC Flexible: 1. Does the switch object act as an input and output? I have...
3,720
