WinCC Prof. TIA portal 13 - Redundancy
grnick50
Nov 2010
Ptolemaida
332
I had an installation with a single user system. All I did to download the project from my laptop (ES) to the operator PC (OS) was to make a shared folder in the OS and download to file system from my PC to that directory. All was well until the project grew and the client requested to add a second redundant server. I am trying to figure how to do this setup. I do set in the runtime settings that the project is redundant and I also set the other server name.
How am I supposed to transfer the project to the two PCs? Regarding the setup of the redundant servers I looked into siemens application note 87054082 but it is not really hepful.
Regarding the download I fail to be able to hit the download button and get the project transfered to the OS. I remember I did it once but it was a nightmare setting up user and user rights and so on.
I tried to do this again by following the instructions of FAQ 88780011 but with no success. I managed to have a directory in the OS PC where I can have RW access from my lapto, however when I try to download I get an error in the compliler which says "THe target path in the operator station is invalid".
I also wanted some guidance to whether I need to use an XBD file for the PCs.
Note that the PCs are regular PCs and not Simatic iPCs
Regards
When we do HMI, we do not have any active components in the HMI. So if we have multiple stations, they can work in parallel and just show the same information.
Do you need to set redundancy at all?
Hello, There is no Audit trail option for the TIA portal WinCC professional. It is kind of built in. For IO fields it is easy to do, but for...
4,525
Hello all, I am connecting an 1769-L36ERM to a WinCC V13 professional SCADA using Ethernet IP. I checked the ST80 Siemens HMI catalog and WinCC...
4,367
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
85
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
91
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
77
