Wincc Runtime V15.1 advanced windows 10
putiss
Sep 2015
Czech Republic
54
Hi guys,
I have installed wincc runtime sw to ipc with win 10. I can load wincc project from my pg, but plc cannot communicate with runtime.
I cannot find pg/pc settings on ipc with win 10.
Is it necessary to install simatic net package or somethings likes that?
If you cannot find the "Set PG/PC Interface", then find the "Communication Settings" instead. It does the same thing. Use it to set the S7ONLINE access point.
I set to comminication in wincc. I have set profinet topology and cpu see ipc with wincc runtime (online wire is green). Problem is that all tags has no information from cpu.
No.
On the target PC, in the Windows Control Panel you have to find either the "Set PG/PC Interface" or the "Communication Settings". Use one of these to set the S7ONLINE access point to the ethernet card you intend to use.
I couldn't find set pg/pc interface, but I manually start it with this link "Setting the PG-PC Interface" = C:\Windows\SysWOW64\s7epatsx.exe -lnl S7ONLINE -App=STEP7
And now it works. Thank you very much
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
65
when i tried to go online, why its showing lie this
97
We are rewriting software for a Simatic PLC/HMI originally made with TIA Portal V16. We will make use of a library that was developed for V17...
1,616
I have a tia v17 project in laptop. I prepared a PC to be used as HMI. In Tıa projecy there is wincc advance. How can I transfer this wincc...
1,371
Hi everyone I'm currently developing my first WinCC Advanced (V16) project. The software is now complete and I can start the Runtime on my...
2,796
