WinCC User Administration
rhill
Jun 2003
Stoney Creek,ON
42
I have WinCC Application that is giving me a bit of trouble. I have 3 user names & passwords in the runtime user administration. When I run it using the Runtime System I can log on and off just fine with all of the accounts. When I load it to the OP177B PN/DP
(P/N 6AV6 642-0DA01-1AX0) the logins don't work.
Has anyone ever seen anything like this or have any suggestions?
Thank you,
Rob
Data
When you compile and transfer to the panel there will be asked if you would update your administation data and if you have recipes also these data.
You have to say yes to save this data to your panel.
I'll did it many times without any problems.
Greetz
I'm officially a dumba$$. The Overwrite Password List check box was staring me right in the face and I didn't see it. I guess I'm so use to AB programming that I didn't look for it.
Thanks for your help,
Rob
Scenario. 3 Inputs on a HMI, each one requiring different User Admin levels lets say: User Maintenance SuperUser Where SuperUser can input to...
1,451
Does anyone know how to do user administration in runtime in WinCC v7? I'm used to work with WinCC flex and there you have an easy to use...
3,999
On my TP177B I want my customer to be able to manage their user accounts and passwords, however, I want to keep a special configuration screen...
2,899
Is it possible to log the user administration in WinCC flexible. I would like to know when a user logs in and out and also wich user logs in.
6,467
Hello, I have a small problem with WinCC Flex Runtime users configuration. I deleted administrator group of Admin user that was in the project...
6,469
