WinCC (v6 - old school!!) question
uptown47
Feb 2008
Over there, next to those boxes
1,146
I've got an old WinCC project and I'm trying to check what tag address certain values relate to.
I have a screen that refers to "Pallet_Data_Description" which, when running, translates to an actual value (such as "Pusher Low Speed Set").
I can find the Pallet_Data_Description tag under "Internal Tags" and, if I hover over it, it gives me the text associated with it (see attached image). But if I go into properties of it I can't seem to find where the 'text' is defined nor what actual PLC address it related to?? (see other attached image)
Anyone any ideas?
http://www.plctalk.net/qanda/attachment.php?attachmentid=48900&stc=1&d=1536835271
http://www.plctalk.net/qanda/attachment.php?attachmentid=48902&stc=1&d=1536835566
Many thanks for any help you can give me on this.
Take a look in scripts, it's most likely been used there.
Scratch my earlier answer.... you were right!!!!
I was looking in the scripts searching for some of the text that was on the screen. However, I've taking a closer look, there is a VB script that connects to a database and the database contains the text!
So the script is just parsing the text in and then iterating through a loop to set the internal tags.
A big thanks for your help Rob. I wouldn't have got there without you.
Cheers :)
Check the Limits/Reporting tab, there is an option to activate and set a start value.
If it's not set or the value is not the same as the current, then there may be a script anywhere where these variables are set.
Hi, I'm not a siemens expert but we recently converted an old siemens PC into a virtual machine so we could run it on modern hardware. It was...
7,837
I am new to the GE Fanuc RX3I PLC. Does anyone have a section of ladder logic from their GE Fanuc Rx3i that they can share with me. Logic...
1,094
Good day experts! There's an old WinCC system (v4 running on Windows NT) that includes Omron CPUs (SYSMAC C200HE CPU42) which communicates via...
3,717
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
31
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
67
