lauwerstim
Is it possible in WinCC to connect to a plc via 2 different networks?
My situation is the following: i have 8 plc's (S7-300), each with two ethernet cards, each card is connected to a ethernet-fiber ring by means of a Scalance switch (the ring itself is plastic fiber, connection between CP-card and switch is normal copper)
So we have 2 ethernet rings, communicatian between PLC's is easy to do this way but connecting the WinCC looks harde because the WinCC has to look to connection 1 until the connection get dropped for 1 plc, then it has to look to the other connection.
So, is it possible?
ps: I know a double ring is quite useless but it's a brain f*rt from a client and he absolutely wants it.
So, is it possible?
