WinCCFlex-OPCServer connection
Krcedinac
Jul 2006
Krca
163
Hello to all,
I`ve been trying to establish connection between WinCCFlex on one PC and OPC server on my laptop trought local network. Comunication from my laptop to the other PC goes both ways, with OPC Scout and WinCCFlex, but in other direction communication goes with OPC Scout but with WinCCFlex it is imposible. When I am browsing the network in the Flex it finds my laptop but it stays "blue" not green with all connections avalble. In the Administrative Tools, Event Viewer WinCCLog I find following message:
General Information
Machine Name: DJORDJE
Time Stamp: 6/4/2008 10:04:48 AM
Windows Identity:DJORDJE\Djole
Exception Information
Message: No connection could be made because the target machine actively refused it
Exception Type: System.Net.Sockets.SocketException
HelpLink: NULL
Source: mscorlib
TargetSite: Void HandleReturnMessage(System.Runtime.Remoting.Messaging.IMessage, System.Runtime.Remoting.Messaging.IMessage)
StackTrace Information
Server stack trace:
at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
at System.Runtime.Remoting.Channels.RemoteConnection.CreateNewSocket()
at System.Runtime.Remoting.Channels.SocketCache.GetSocket(String machineAndPort)
at System.Runtime.Remoting.Channels.Tcp.TcpClientTransportSink.SendRequestWithRetry(IMessage msg, ITransportHeaders requestHeaders, Stream requestStream)
at System.Runtime.Remoting.Channels.Tcp.TcpClientTransportSink.ProcessMessage(IMessage msg, ITransportHeaders requestHeaders, Stream requestStream, ITransportHeaders& responseHeaders, Stream& responseStream)
at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Siemens.Simatic.Hmi.Utah.SystemDiagnosis.TraceServerDispatcher.Ping()
at Siemens.Simatic.Hmi.Utah.SystemDiagnosis.Tracer.Connect(Int32 pid)
For more information, see Help and Support Center at
I tried with DCOM settings, firewall, etc but I can not get it throught. If it was the same for OPC Scout I would understand but like this no...
It is WinCCFlex2005 SP1 HF7
Does anyone has any ideas?
Regards
I have never fumbled with DCOM, only looked from the sidelines.
Can it be that the userprograms that connects via DCOM have to be assigned access rights on the remote PC ? Maybe OPC scout has some rights, that WinCC Flex does not.
Hello Jesper,
May be, but why in the other direction (from my laptop to PC) it works with the same DCOM settings???o_O
I am using the time interval logging functionality on a MP377 panel. Log files are periodically copied and stored onto a flash card, so far so...
2,386
Hello ! Can somebody help me with report of production in winccflex 2008. Now I can see and can print only last cycles of production, and I want...
2,720
Hello everyone, I was wondering if it is posible to communicate an S7-1200CPU with a WinccFlex runtime (running on a PC) via Internet. I don't...
3,426
Hello! I have problem with screen in winccflex 2005&2008. When start runtime start screen is normal,but when go to the other screen and back to...
3,022
Hi there! I have a problem with StartProgram command in Flex. I made an application in Borland C++ builder what works with files from the current...
1,991
