WinCe and Siemens monitoring software
Bratt
Nov 2003
West Sweden
726
Does anybody out there know if there is any monitoring software for Siemens S7 300/400 or S5 series that can be used with a pocket pc running Windows Ce. I Noticed that Narly Software has a version under construction and was therefore curious to see if anybody have heard about any other companies that have already developed versions.
Bratt,
The one from CiTechnologies seems to be finished and on the market. It's called CitectScadaPocket and is intended for Pocket PC. Windows CE is not mentioned on their website as such, but I believe they mean WindowsCE when I read the specs. You can even download a demoversion from here .
I have seen a version of WonderWare InTouch on a pocket device some years agoo, but I believe that was a Palm and not some WindowsCE device. You should check on their website, don't remember the address right now, so you'll have to google for it.
Kind regards,
Hi, I have soft PLC Beckhof CX1020. This runs on WinCE 6.0 problem is when i connect touch display to usb port, touch screen don't work...
1,031
Hi, I'm looking for a method to uniquely identify TP1200 HMI panels. At first we tried to use this: Dim object Dim computerName Set object =...
2,170
I want to call an executable (or .bat-file )from inside a script using WinCC Flexible 2007. :scratch: Searching the net always seems to return...
5,591
Before I get flamed I did try searching for this but there was very little posted about WinCE. I am starting to get tired of having to program...
4,767
Hello to all, I'm trying to figure out how to get a Windows CE touchscreen to run an application developed in VisualStudio.NET to talk to an...
2,053
