Peter Nachtwey
Hint, cosine law.
What, no graphs?PThis attempt is in sheet "sin cos"
Dan Bentler
What, no graphs?
Peter
What I calculated was the periphery - I just discovered one tiny error - I did this while stationary - now I gotta make it turn and redo calcs. Let me study law of cosines and learn how to use it.
Was a good review of trig. Thank God I still remember Suzy can tell.
Dan Bentler
You didn't use the cosine law. Also you are computing the velocity of the wire given the rotation of the square spool when you want to compute the rotation rate of the square spool as a function of the velocity of the extruded material and the angle of the square spool.Interesting to note that distance to barrel center has no effect on velocity. This leads me to believe the above is incorrect.
That is the forth step.Another required step is to find out the limits for which wt is true. You would do this by finding the angle of a when it is equal to 90 - Arg(root(2)d(cos(alpha)i * sin(alpha)j))
