Winding technology.
Peter
I assumed a square 4" on side and one RPM. Solved for single revolution.
I did it using tangent. The problem I found using tangent is you can only do it it 45 degree "chunks", tan of 90 is undefined so I added total periphery of a 45 chunk to preceding 45 chunk. Can only give tabular data.
y = 0.044x linear regression is R2 = 0.9997
Not much help I admit for accurate motion control.
See att'd file both chart 1 and sheet "tangent".
I tried using cosine combined with sin works fine until 45 but over that it all falls apart could be done but I think would have to do in 45 chunks.
This attempt is in sheet "sin cos"
Dan Bentler
Start with the cosine law
I provided step 1
http://en.wikipedia.org/wiki/Law_of_cosines
In the picture in the link assume that 'b' is the distance from the center of the winder to a corner of the the square spool. 'a' is the the the length of the extruded material and 'c' is the distance between the source of the extruded material and the center of the winder. The rate of change in the length 'c' is the extruder speed. What is the rate of change in α as a function of the extruder speed and the angle α. Finding the derivative is the second step.
Peter
What I calculated was the periphery - I just discovered one tiny error - I did this while stationary - now I gotta make it turn and redo calcs. Let me study law of cosines and learn how to use it.
Was a good review of trig. Thank God I still remember Suzy can tell.
Dan Bentler
Peter
Dan Bentler
? Huh ?
knutabru - Please provide a drawing showing the path of your thread before the winding drum and also indicate the true shape of the "square" winding drum.
I found length from extruder to barrel edge to be:
where d = width of barrel.
and L = length from extruder to barrel center.
a = (root(2)*d*cos(alpha) - L)i + root(2)dsin(alpha)j
Given alpha = wt
a
(t) = (root(2)*d*cos(wt) - L)i + root(2)dsin(wt)j
Then:
v(t) = (-w*sin(wt)*root(2)*d)i + wcos(wt)*root(2)*d*j
From this you could find the magnitude and %variation from peak and use it to scale your w.
Interesting to note that distance to barrel center has no effect on velocity. This leads me to believe the above is incorrect.
Another required step is to find out the limits for which wt is true. You would do this by finding the angle of a when it is equal to 90 - Arg(root(2)d(cos(alpha)i * sin(alpha)j))
You didn't use the cosine law. Also you are computing the velocity of the wire given the rotation of the square spool when you want to compute the rotation rate of the square spool as a function of the velocity of the extruded material and the angle of the square spool.
That is the forth step.
Y = length of extrude to barrel (easy to figure out)
Y' = V_extrusion
L = distance of barrel center to extrusion
r = 1/2 width of barrel
YY'/(root(2)Lr) = wsin(wt)
LHS are all known values. RHS has multiple solutions eliminated by calculating the range.
My attempt
My attempt This uses Cosine rule
- probably have the velocity wrong (had to look up the derivative)
Also in this application we are not looking at the winding angle onto the drum - ie If my pictures are looking from the side then we are not worrying about looking from above
The pdf is for those who do not have Office 2010 - the conversion munched my circles and squares into ovals and diamonds
Zip file contains Excel xlsx as only xls files are allowed to be attached
View attachment Square Winder.pdf
Errors seen after a good night sleep
1) Velocity is negative
2) in the Start and finish angle calculations The Sqrt(2) should divided not multiplied
probably comes from not trying to get a graph (working on that)
The traverse axis removes all worries about looking from above
I think someone mentioned using current/torque control - problem with this is the effective radius is changing constantly so the tension in the thread will changing
You are very close and on the right track.
Good show so far. You have a problem with a sign. My numerator would be c1+v*t where c1 is the initial length at t=0. I think you have an extra v in the numerator. Also we disagree on some signs under the square root.
I still need plot this. I haven't spent much time on this to work it out completely. I use wxMaxima to do the calculus.
Good Evening , Looking to upgrade and automate our motor rewind shop . I was on YouTube looking at some automated coil winders .Who are the...
1,198
Hello guys, I am facing the ground fault problem often. We have a liquid mixer machine and the motor is installed under the mixer tank.so...
26
5,861
Hi Team, I am working on one Paper Coating machine, My Winder, infeed, Coater and Unwinder is runnning through ABB's ACS550 VFD, My winder is...
1,329
Hi I can make the this pictures system. But my master motor AC motor and Slave Motor Stepping motor. I have the PLC and main motor shaft encoder...
1,232
Hello, Looking for advice or sample code for a traverse winding application... I'm upgrading an old machine that was using a structured text...
1,674
