Window 7 and RSLogix 500
welshwizard
May 2011
Wrexham
Can anyone tell me if RSLogix 500 will run on Windows 7 (64bit), I know AB only support it on (32bit) PC's but I don't want to spend on a starter set of software if it will not run on my PC.
I know RSLinx will run on (64bit) PC's with RSLogix 5000 which confuses me that AB have not done supported 500 software for it.
cheers
:geek:
RSLogix 500 version 8.40 appears to have been released today (or at least sometime this week).
It officially supports 32 and 64-bit Windows 7.
OG
Cheers OG
I will ask about that because the other day the reply I got from Rockwell is below so I was unsure about purchasing the software.
Official Support
Windows 7 (64-bit)
RSLogix 5000 v19.00 and greater
RSLinx Classic v2.57or greater
Windows 7 (32-bit)
RSLogix 500 v8.30.01
:geek:
When opening some RSLogix 500 program files, my RSLogix window is re-sized smaller. The same thing happens when I go from offline to online. Once...
4,653
:banghead: This is an issue that has bothered me for some time. Does anyone know how to make the browser window for searching for matching offline...
3,075
Whenever the program starts, the bottom of the ladder logic window is behind the taskbar. I have to drag it down and resize it to see the...
17
11,626
Hi There I Am Going To Buy A Used Rslogix 500 V 6.0 (standard/rpo) Or V7.0 (standard/pro) Over Ebay. Are These Softwares Working On Windows Xp...
6,624
Has anyone else ran into the bug/phenomenon where if you have 2 logic windows open, or a window split that when you make a rung edit online in one...
2,280
