Windows 10 Rockwell Next Gen Fail to Edit
gtg142r
Aug 2011
Dalton, GA
Hi all,
Over the past few months, we have been experiencing an issue with our PCs that I wanted to reach out and see if anyone else had experienced. What happens is that at some date (has happened at different timelines on different PCs) our PCs suddenly stop being able to edit "next gen" programs (1756-L8 series and 5069 processors). If we try to build/do online edits/download to one of these processors, we get "Error: Compiler Error. Call technical support." This only happens with Windows 10 machines and has happened with multiple builds of Windows 10.
Does anyone have a workaround for this short of creating a VM on everyone's PCs?
Hi all,
Out of curiosity, did you actually call Tech Support to learn more about the error?
Hello, I have experiencing the same error. Did you solved it?
I cant tell you nothing about the error itself, but from my experience with Rockwell you have to give them at least 6 months to do something about a problem. The first 3 months they try to convince you that there is no problem. Then maybe they take a look at the problem itself. And ... ... maybe they decide to do something about it.
Solution
Yes, we did get a solution worked out. It turned out that on the 8-series PLCs that the compiler launches a virtual drive momentarily but is never assigned a drive letter. Even though our IT department has App Locker without any restrictions, it would not execute due to there being no valid path (due to no drive letter assigned).
Tl;dr: Yes, you have to get your IT department to disable App Locker.
KB: BF15281 suggests that an antivirus software, or Windows AppLocker is blocking the compiler. That article has a TechConnect access level.
edit: it apparently took me 7 minutes to write that one sentence lol
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/1133982 What kind of hiccups could be expected before Rockwell puts out...
4,445
A couple of years ago I posted about my exploits getting as much rockwell software as possible installed on Windows Server 2019. I've taken the...
31
19,679
Good Evening , I'm in the process of retiring a Dell XP Laptop. I'm starting to download RS Logix 5000 version 15 , 16 , 17 etc. Then the...
6,446
Good Morning , I'm getting ready to take the step of retiring our Windows XP laptops. We have a number of older ControlLogix CPU's and...
35
9,520
On my base w7 machine, everything works perfect. I have a w10 clone that I wanted to test rockwell on, even though it isn't supported. I have...
1,991
