Windows XP
401Bill
Oct 2005
Kentucky
Can someone please tell me if "Windows XP Home Edition" has the "System Restore" feature on it that allows you to restore the computer to an earlier time? I know that the Professional Edition has this.
As Ron pointed out Yes. Problem is if you leave it on and run into an issue and keep rebooting you'll eventually be restoring with the screwed up settings. My advise is to turn off system restore after you are sure that your machine is clean and stable. Then when you go to restore you'll restore to thoes settings. If you load some new software be sure to turn on system restore, reboot, then turn it off again to save the new config in the system restore.
exactly, it will backup only system dll's and choosen executables, other suspicious extensions and configuration files like 'installed programs information or registry '... this is better than nothing, but will not solve much ... you'd better use some partition-based backup application instead of this imho
croakus said:
Marius,
What do you mean by
What would you recommend for an XP Pro OS?
Mike
What he means is to backup your OS on another drive or partition. That would make for the quickest recovery. Drive space is cheap compaired to the time is cost$ to recover.
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
35
Hi everyone, I have an issue with installation of Studio 5000 33.00.02 DVD Media disc 2 with View Designer on Windows 11. After installation...
121
Hello all, Hope everyone enjoying their weekend. I just recently bought a laptop to upgrade my old one with i3 its getting slow on me. But when i...
435
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
345
Hi all. I received two identical brand new Dell desktops from a customer to install the softwares for a project. The first one is for a...
531
