WinnCC Flexible and Step7 integration
zrawi
Mar 2004
Riga
41
When I installed WinCC Flexible it was saying that my Step7 (5.3) version is old and needs to be updated up to SP2, and as a result WinCC did not integrate into Step7.
So after installation I downloaded the SP2 for my Step7 and installed it succesfuly..
Now I wonder how can I integrate WinCC into Step7 without reinstalling it..
Can someone give me some tips on how to do it?
I think that it is as simple as open the project in Win CC Flexible, chose the function "Project .. Integrate in STEP7", and then point to the STEP7 project of your choice.
You may want to check the communication parameters afterwards.
Hmm.. I dont see such an option (Project -> Integrate in Step7).. What could be the problem? Some configuration..
I started to learn WinCC this week so don't laugh if I ask something stupid.. :)
Dont you get this ? :
The problem could be a nasty case of a registry error.
I previously had a similar problem, and I had to deinstall all Siemens programs (!), delete entries in the registry manually, and delete some files manuelly to cure it.
Ok, I get it..
When I start WinCC in the Project menu those two options (Integrate in Step7, Copy from Step7) are disabled.
It seems like I will have to reinstall this software..
Thanks for your help!
Do you have an project open ?
They will be greyed out if no project is open.
If you have to reinstall the software then search for "complete deinstallation" on siemens support site.
When you reinstall the software, start with STEP7 !
Can someone help me. When I open winncc flexible I do not have a toolbar to open or create a new project. I have not used this software yet so am...
2,003
The code below is all in one script called by the main screen. I have 2 buttons. Move record forward and move Record Previous. What i need to do...
3,785
On the HMI-1200, the Wall clock date shows "1/4/1970". How can I correct this? Can't seem to find where this date is coming from or how to change...
910
In wincc server client configuration with redundant server, if the primary/master server fails and the standby does not takeover. How to...
1,431
I have an odd situation where I turn on a valve on the HMI, and the output in the PLC is on and indicates ON in the output map. But the actual...
1,832
