WinnCC.Trying to Debug Script? Debugger???
smcmanus
Jan 2006
Vancouver
109
Hi. I am writing VB Script in WinCC but cannot open the debugger to debug it. I installed the one from Microsoft but none pops up when I hit debug!! Thanks for your response.
In WinCCExplorer, in Computer > double-click the server > Runtime tab > Select for both VBS Debug options:
-Start debugger
-Display error dialog
When in runtime you run the script the debugger will give info if there are problems......
On the HMI-1200, the Wall clock date shows "1/4/1970". How can I correct this? Can't seem to find where this date is coming from or how to change...
927
In wincc server client configuration with redundant server, if the primary/master server fails and the standby does not takeover. How to...
1,437
I have an odd situation where I turn on a valve on the HMI, and the output in the PLC is on and indicates ON in the output map. But the actual...
1,844
We are trying to trend data between 2 separate systems. They do currently share some information between pics (Siemens 400s). Is there a way to...
1,142
Hello I have a project for which I need to convert Protool to WinCC for an upgrade. I have WinnCC Flex SP2 but its the Standard version and I...
3,645
