Wire Color Code
wayne
Apr 2002
Windsor
21
I have been reading the past posts about color coding standard.
I cannot
understand why you would use Blue as DC+ and Wht/Blue as 0VDC
when the manufacttures on all their sensors use BROWN +24VDC
BLUE-0VDC and black as the switch. Can someone explain this to me.
A lot depends on company standards.
One of the big corporations that I did a lot of work for used brown for jumpers only.
Their projects may have 10 or more colors for 24vdc.
I came up with the idea of using an Excel speadsheet for the numbers, which I could sort by number, location, etc. Also, with Excel, I could color code the "line" and make it match the color of the wire.
Obviously, white was a problem, and yellow was sometimes hard to read.
With 24vdc, there is no "LAW".
regards.....casey
Especially recently, manufacturers design sensors that have a range of operating voltages and use QD style connectors. Blue has been used to signify 24V and red 120 but what color wire should I use if I build a sensor that can handle both voltages?
My latest controls systems uses Allen-Bradley QDs that have all red wires with different tracers but the controls on the ends of those QDs are 24VDC (with blue wires from the panel...).
Brown/Blue is the European color code -
Brown indicates the hot line, blue indicates the neutral line. Its seems to be used on both AC and DC systems.
We are creating a CE compliant version of one of our products, for sale in Ireland and the UK. We would like to use Brown for VDC+ and Blue for...
3,980
Does anyone know the color code for wiring a 4 wire dc device. I'm pretty sure brown is for 24vdc, blue for 0vdc. I'm not sure about white and black.
2,538
Does anyone know the color code for a 4 wire dc device. I'm pretty sure brown is for +24vdc, blue for 0vdc. As far as black and white i'm not sure.
19,066
any one can help me please what the color of control dc voltage (24v dc & 0v dc ) and ac (phase and nutral) that associated with standerd IEC
4,074
Hi guys, I've got probles in color on the PLC terminals. what color should be on the low voltage wires? Blue on both positive and negative? and...
20,350
