Wire labeling (self-laminating)
phuz
Jun 2008
Mohnton, PA
1,044
I'm sure to get some dirty looks for posting this in a PLC forum, but I know there's a lot of experience in here. Every now and then I'll build a panel if it's small enough. I have a Brady IDXpert labeler and was using XSL-11-427 self-laminating labels. I noticed that after a bit, they start to come undone at the end of the translucent part and it looks ugly. Are these not the right labels, despite Brady selling them as wire/cable markers or maybe I got a bad roll?
I use XSL-32-427, I think they are the same just different sizes
I dont know of any better but if you put them on right they seem to stay good... not great but good, the trick for us is that getting the cable/wire tight and straight before putting it on and wrapping it tight
Part of the issue with these labels may be due to temperature. If the panel is warm/hot inside, the adhesive is less permanent. Also, if they are handled a bit during application, same thing. When I worked for an OEM machine builder in Detroit we used these a lot, but not all our customers wanted them, maybe for that reason. Nowadays I have our guys use the heatshrink tube style labels; they are a lot more durable. I also switched to a K-Sun labeler; a lot easier to get results from it... sorry Brady!
I use the shrink tubing labels from Brady put them on the wire terminate the wire alien the labels and use a heat gun I don't have trouble with then unwarping and easy to read after the job is done.
I thought about this. Got a good recommendation for pre-cut transparent shrink tubes for something like this?
Warm temperature isn't the issue. I was wondering if cool temp maybe, because it was 50F in the shop. Also wondering if natural oils in the fingers may do it?
I had a brand new cartridge of the XLS-96-427 which I opened and wrapped on a wire in 70F as a test. The bottom picture shows the label after 3 hours. Top wire is after wrapping the wire in 50F and sitting overnight.
There is something wrong there. No label should ever start peeling back after that short of a time. I have seen then often peel like that after about a year or so.
But that's one of the reasons I started using the shrink tube. After years of service they are still attached and readable. I have never seen any clear ones though. If I could fins some I would like to try them to see how they work.
I agree, mine start to peel back but thats after several months or longer, I think you have a bad cartridge
Still, even months is horrible. I'm in front of the computer most of the time, so when I get these opportunities to do small panels, I like to take my time and make them look as pretty as I can. I'd want to open the panel 5 years later and still see those labels intact. The heat shrink will add extra time, but it sounds like the option I need.
Dont get me wrong, that was extreme conditions... I have some from back when I started 2007 that still look great, I do have some in storage containers that get 140deg + with about 95% humidity that are starting to peel back on some
Do the all white labels tend to stick better than the self laminating translucent ones?
Not sure, we only use XSL-32-427 and they are small part of white with the rest clear.... with as much as they charge for these you would think they would stick good :cool:
Our existing control system has vinyl labels that were printed with the old ink cartridge/dot matrix system by BRADY probably 15-20 years ago. In...
4,787
Is there a standard or guideline to wire labeling? I have some experience as control engineer , an depending on the PLC brand being used we...
20
7,331
About to install a new control panel we built and out wire numbers are 4-6 digits. We use the Brady heat shrink type labels for our wires but when...
3,042
guys i have a panel to build that has about 300 i_O some plc and some hard wired . my question is i see some people use the plc address for the...
3,348
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
265
