wire labeling
MNJ96
May 2005
Salem, Oregon
50
guys
i have a panel to build that has about 300 i_O some plc and some hard wired . my question is i see some people use the plc address for the wire number on plc i_0 and the line refernce for the wire number on hard wired circuits i use line reference as my page numbers also example all wires 900-999 are on page 9 of the drawing set . only using the plc i_o address would limit this function you would not know quickly on which page of the 40 page drawing set this input card or output card was on . is there anyone who see anything wrong with doing both example I:7/01-422 OR 422-I:7/01 i can fit all this on 1 label easily i am using brady id expert heat shrink markers any suggestions thoughts or comments are much appreciated
For me i would say it doesn't really matter..as long as the people who look after the system know what your intent is they can figure it out..
Thinking a little more about it perhaps the wire number should be first..becouse you have both in the same cabinet..Just one mans opinion
phil buchanan said:
Doug
Which Do You Think Is Best Address First Or Wire Number ?
Doesn't matter, as long as you are consistant. Pick one and don't change it.
Personally, I would go for Wire Number first, then IO number.
Doesn't matter just spell it out on the print. Sometimes I will just make a small note on the front page of the prints. Sometimes while looking through prints I will see a note like this. After reading the note everything comes together. So I try to always put little notes to help who ever is looking. It takes out all the guess work.
The slightest pencil mark is better than the best memory..
I'm sure to get some dirty looks for posting this in a PLC forum, but I know there's a lot of experience in here. Every now and then I'll build a...
2,701
Our existing control system has vinyl labels that were printed with the old ink cartridge/dot matrix system by BRADY probably 15-20 years ago. In...
4,787
Is there a standard or guideline to wire labeling? I have some experience as control engineer , an depending on the PLC brand being used we...
20
7,331
About to install a new control panel we built and out wire numbers are 4-6 digits. We use the Brady heat shrink type labels for our wires but when...
3,042
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
265
