Wireless access points
JeffKiper
Jun 2006
Indiana
2,461
Does anyone have a recommendation for a wireless access point that they like? I am putting them on a controls network with no DHCP. Everything is static.
I've used several Ubiquity units but I have to run their controll software on my PC to set them up. If my PC crashed or I update the PC I have to default these units and start from scratch. They have a controller that sets on the network just so you can access their AP. It will work but I'm not a fan of them.
What are you trying to do? Is this for the plant network/comissioning, or are you looking to do IO over wifi?
I guess that would help to know the intentions. We will be using this for plant network access and commissioning. No IO over wireless.
I've used the Phoenix FL WLAN 1100 with good results. My application was a machine that was solely controlled by an iPad using Ignition Perspective, and it's been rock solid. That said, since the user is always right next to the machine with the iPad, I can't really comment on it's range. According to the specs it should be quite good, and I have no reason to suspect otherwise, I just haven't had any direct experience to prove it.
TP-Link Omada AC1750
Been using this for a year now commissioning a plant, range is crazy for the open concept plant I'm working in.
EDIT: I have Ubiquiti at home, but for the same reasons you mentioned I wanted something that was easy to configure as a simple access point.
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,031
Hello all, This is my first post, so i hope im doing it wright. Let me start by saying im not a PLC pro, i started to learn programing on my own...
3,846
So I have a Ethernet loop located in a tower about 350 feet above ground I do not care to climb up to program the system so I want to install a...
2,847
Hello! I'm currently trying set up our department with wireless access for the PLC network on our site. When connecting to smaller local...
2,451
Hey everyone. I have some portable assemblers with Micrologix 1100 PLCs that I would like to connect to my Plant Network for SCADA. I am...
1,835
