Although I see the merits of the suction cup idea I do not believe it will be feasible in my scenario. See if this explains why.
The operator takes the test vehicle to the entrance of the test booth, who's entry doors are default open position, he drives the said vehicle into the test booth down a set of guided tracks through the entrance, down the dry off booth, approx 20' long, then into the spray booth which is also approx. 20' long. Once inside of the booth a dual channel pressure pad activates the initiation of the sequence, which closes the doors then enables the water flow valve and initiates an AB Powerflex 700 VFD PID controlled by a pressure transducer to regulate the pressure delivered to the sprayheads. This is the point where the customer has requested remote interruption to the sequence. The cycle initiates its cycle, which varies from 8-12 minutes based on the vehicle, and when completes, shuts down the VFD. When the vehicle is detected leaving the pressure pad initiates a series of 25 HP blow off motors to dry the vehicle off, when the vehicle is assumed through the dry off sequence a photo-eye is broken which shuts down the drives and begins the initiation of the door open sequence for vehicle removal.
So this is the dilemma I am in for a hard wired solution, not only is it a test to determine vehicle seals and the like it is also performed in a test booth that is approx 40-50'ft in length and is auto started. Plus it is not what was requested by the customer.
Now in all fairness I like the methodology of the method you are suggesting, the practicality of it leads me right back to the remote wireless functionality.
Now in reality, with the pressure pad initiation required, which is dual chain, self redundant, through a safety relay, if the driver backs the vehicle up a few inchs the process will also terminate, the remote is just a "cleaner method" to stop the test. Now if I use a 4 channel remote device, now I can have him just press the button to stop the sequence, and if he so chooses to resume the cycle, depending on the remote device used and channels available, this is now possible. I already have a hard wired method involved, just gives additional options with the remote capability, and the current technology should easily accomodate this without the hardships of hard wiring complications.
So under the circumstances I am still sticking to the remote function, and that is what the customer is asking for, and you know how that goes, the customer is always right, except for when he is wrong, haha, but he is still right if ya know what I mean.
So with all of the hard wired suggestions, thanks but I am sticking to the remote capability, as to my customer request. This is not being offered as conditional, it is a requirement so that is what I need to stick to.
