maintenanceman38
I need to tell a pump to turn on or off from a great distance about 4000 feet. The plc I am using for controls, (DL-05). Has it's only slot used up. That much wire may be too expensive and all i have is 20 ga. The voltage loss may be too great. I would like to use a Roving Networks Wi-Fly module in adhoc mode to transmit a signal. I can use a repeater to boost the signal. and a Wi-Fly module to receive. Can the transmitter be in adhoc mode and have a static Ip address? does anyone know if this can be done and how?
