WirelessHart as data exchange interface
nideal
Mar 2015
Belo Horizonte
We want to integrate a dedicated PH PID controller, implemented in a small PLC, to the main process controller. The basic idea is make possible sending the ph setpoint and monitoring valve position from the control room. There is a WirelessHart network already working, monitoring some instruments around the field. Is it possible to use any kind of adapter, module, card, etc, to exchange data between those controllers? Any advice about making the ph controller a wirelesshart node, as the others network devices? Maybe we need an analog input/output interface communicating through wirelesshart.
Hello, Anyone that has any experience with WirelessHART? I am looking at A system where I need to poll the processvalues from 15 transmitters via...
1,455
Dear, I´m working now in my thesis of degree Electronic Engineering and I have the next problem I´m need connect the gateway wirelessHArt SWG70...
4,021
145
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
67
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
50
