Wiring a Micrologix 1400
rmb550
Nov 2009
Ontario
86
I have been struggling with AB's User Manual for the ML 1400. The outputs on the BXBA version say they have 6 relays, 3 high speed DC outs and 3 normal DC outs. I can't figure out from the manual which ones are which. Also, the diagrams in that manual are confusing. One shows all 25 points, another only shows selected ones. Why is it so difficult for AB to just print a diagram showing what is connected to each terminal? I tried contacting them today, but it seems like I have to give them money to discuss shortcomings in their documentation.
GRRRRRRRR
rmb
It is a bit vague as you said, but here is a link to a manual, see page 21, 22 and 43 for the terminals info.
Good luck. I hope this helps a little.
Link:
http://literature.rockwellautomation.com/idc/groups/literature/documents/in/1766-in001_-en-p.pdf
Edit :
Page 31 says outputs 2,3,4 are the high speed DC outputs so outputs 5,6,7 should be the normal DC outputs. Outputs 0,1,8,9,10,11 are isolated relay outputs.
You didn't ask but Inputs 0 thru 11 are high speed DC inputs. Inputs 12 thru 19 are standard DC inputs.
Thanks jr that's exactly what I needed to pull it together. Not sure why they feel they need to spread this over so many documents......now I will find out how fast they can deliver the controllers.
Cheers!
rmb
jr thanks for the edit. The version of the document I had was IN001B (and not that old) it seems Rockwell answered all the questions with this October 2009 Revision.
My local rep said he was putting 4 ML1400 in stock, his only issue up until now had been CSA approval - he would only sell us devices if he was assured the end product was not remaining in Canada - but we understand that is now looked after. I will report back on what they tell me P&D.
Thanks for all the great help here, it's the BEST source of tools & tricks & clarifications.
RMB
Hi Everybody just wondering if anybody would have a wiring diagram for the inputs for a Micrologix 1400, is it just take the 24Vdc + from the plc...
4,844
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,432
Hello, After searching the web a bit, I am still not quite sure how I should go about wiring up this controller. It is mostly built for 120V AC...
2,057
How can i connect/wiring auma actuator to ml1100 (1763-l16bwa) for open, close and stop.
1,845
So I recently purchased a micrologix 1000 1761-L16BWA from ebay to build a PLC trainer. Watching videos on the topic lead me to believe that the...
5,842
