Wonderware 10.0
Basso
Jul 2010
oslo
Just try to installed version Intouch 10.0 to my computer, system is Windows XP 2.
Then i get a message Rainbow sentinel setup failed to complete successfylly.
Is there anyone who can help me.
It's part of the Pre- requisites for installation. Run the setup again and read carefully before progressing. Normally if you don't have it installed it is included in the setup and it will install automatically.
I'm getting the same error, I accept everything and it keeps failing for some reason, anyone fixed this issue before?
Nevermind, your problem might be that you have a newer version of rainbow sentinel installed. If you wish to install WW10 you are going to have to uninstall the sentinel first, and then run WW10 Setup again. It worked for me.
Been through this with Intouch 10.5.....
I assume you also installing an IO Server? If IO server is older than Intouch 10, that may be your problem.
Depending on the version of the IO Server, you may need to install it first.
Intouch and the IO Severs both setup the Rainbow Sentinel key. Yet, there are different versions of the Rainbow install. Obviously...You want the newest version.
Try installing the IO Server first and then Intouch.
I used to get this problem all the time, you need to select custom install (browse the disc under redistrubutibles/rainbow etc.) and tell it not to install the parallel port driver.
174
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
116
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
203
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
197
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
175
