Wonderware FS Gateway [OPC] [Intouch]
juliasakamoto
Feb 2018
Rio de Janeiro
Does anyone know if FS Gateway has a limitation of number of tags?
I was told that it has (up to 25k I/O tags), but I can't find any document that confirms that information. o_O
Well, only to clarify for those who have this same question:
I talked to Wonderware technical support and they told me that FS Gateway doesn't have a specific limitation, but they recommend, as a good practice, 25K I/O tags for this drive.
hi, I am currently working on a project that requires access to the data inside plc using Codesys OPC server v2.3 and I want the data to be...
3,026
I've already done everything that I could (including reading all of the Tech Notes) but could not read the simple tag throu FS Gateway 1.5 (OPC...
6,739
Windows Server 2003 SP2 ArchestrA System Management console 0027.0021.0000.0000 Whenever I try to add any object to the ArchestrA.FSGateway.2...
9,763
Hello and good day to everyone, I need someone help on setup a communication between Omron CJ2M + Finsgateway + Wonderware. I already create all...
4,242
Hi, I am having RSLinx Gateway and WodnerWare Intouch 10.0. I want to connect ControlLogix L63 processor with Ethernet IP(1756-ENBT) to...
18
35,314
