Wonderware - Installed Software
user173
Jul 2014
Germany
20
One of our customers has a PC with Windows XP and an InTouch Runtime. That's all he knows about the system.
He wants a new PC with Windows 7.
What he needs to do in order to be able to tell me which Wonderware-software is installed (InTouch-Version, I/O-Driver...).
It is far to go there.
Are there any files in Wonderware-software where I can read "...It is InTouch 9.0", "...It is the I/O-Driver xyz" ... ?
Thanks for your help!
Most likely the version he has is not compatible with the new operating system. And the version will need "upgraded".
you should be able to open the SMC and find wht DA servers he is using and how it is setup.
If you close the viewer and open "intouch" it should give you the version. or just find his wonderware license file and open it in notepad.
If it's running on XP, then the application might be using a Wonderware SuiteLink IO Server. If so, you'll need to change to a DA Server. Depending upon the application, you might have to make some other changes manually after converting to a newer version of InTouch.
The idea with the wwsuite.lic I had already, but then I only see what is licensed, not what is installed and used.
On Siemens Systems there is a program named "Installed Software", whose output is a list of all installed/licensed Siemens-software. I was hoping, there would be something like that in Wonderware.
Can he run up Windowmaker, or even Intouch (not windowviewer on its own)?
Then go Help, About and that should give the running version.
I have about 40 systems here and during my discovery, it is what I have used.
Is the wwsuite.lic runtime or development?
Or you could install something called "Belarc Advisor" http://www.belarc.com/free_download.html
which when you run it on your pc, gives things like installed programs and network connections etc etc
Just yesterday, I was installing InTouch V9 on a Win7 VMware machine and it would not run up, so had to drop back to an XP machine to do so, so do watch what you have.
I do use the DAservers now for PLC comms, although stil have ABTCP on the older machines.
The easiest way is to open Intouch and click on Help > About. I have gotten into the habit of including a "Computer Information" screen into my apps just for this reason.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
159
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
106
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
190
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
184
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
169
