Wonderware Intouch 10.0 - Blinking two pictures that are representing one symol
After looking at your example, I see you've found the solution. You've got bitmap images in different colors, representing different states. WW doesn't allow color animation on bitmaps so you use visibility and blink animations on stacked objects. I saw this in another application several years ago to make a pump show Stopped, Running and Fault.
It's possible to draw and animate a number of simple objects, group them into a cell and do tag substitution, but that can be more work than making a bitmap and saving it in different colors.
I have added a $Second datachange script, as well as modified the animation attributes of each object.
I have tested with the 2x tags you had defined, let me know if this serves the function of what you require.
My apologies, I thought I had, but when I tried to do so again, the file was to big for the forum. If you send me a PM with your email, I can do it that way.
Alternatively, I can try and post some screen shots later tonight.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
158
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
411
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
187
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
480
