Wonderware Intouch 10.1, Cannot start topic
ason
Oct 2005
Home
317
Hey, i have upgrade a intouch application to Intouch 10.1
And when i start the S7 I/O Server before intouch viewer it works ok.
But if i dont start the I/O server i got a message that tells me that cant access the TOPIC.... Start application S7.EXE?
And i press Yes,
i have next message, ........make sure the app. is correct and that the location of the app. is included in your path.
Know i wonder, where can i change so s7 i/o server is included in my path?
But what if the IO Server should not be a service?
set application for that access name to none, write a app script on startup to start the driver, then change the application to the driver after the app is running using I believe the IOsetaccess script.
I guess the better question is why not run the driver as a service?
Now i have it as a services,
But one more time,
Is there any way to change so i have S7 i/o server included in my path?
Hi all, This is my first System Platform 2017 install. Have done plenty of mods to existing 2014 R2 installs and know what I'm doing in terms of...
5,119
178
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
178
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
452
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
215
