Wonderware Intouch 9.5.100 - Weird Problem
Grendizer
Apr 2012
Toronto
88
Hey All,
I am having this strange problem. It is so weird that I did not know what the title of this form should be.
I have a "AlmDbViewCtrl" active x control; Named it "LRF1AlmDbViewCtrl". In a quickfunction, I do some logic for it. The issue am having is that Sometimes when I go to that quickfunction and click validate, it gives me the error " "LRF1AlmDbViewCtrl.Refresh" is a reference to an unknown or unregistered OCX", and if I go to the control and just open its property box and close it, the issue goes away. It seems like if a refresh the property box, it recognizes the name. I don't get it!?
Any ideas?
Thanks,
Grendizer
Hey all, Is there a way of checking if a tag exist in the Database through scripting? Like maybe a function that check for tag existence? Thanks,
1,486
Hey all, Is there a trick of opening a multiple instances of the same window? For example, I have 5 buttons that open the same common pop-up 5...
3,149
Hey All, Is there a way of dumping tags associated to a specific screen? For example, I have screens x, y and Z and I want to dump ONLY the tags...
3,891
Hey All, I just started to have this issue with Intouch Viewer. When I start Viewer, it works normally, then, after x amount of time, Viewer...
4,747
Hey all, Am trying to rename tags, thousands of them, without having to open the "Tag Dictionary" and modify them from there. Is there a way of...
21
17,873
