Wonderware Intouch acess name dde to another
veoteveo
May 2008
Mexico
20
Hello,
Need to know how to dde data in one intouch application to another
tagname:temp1
access name: DDEintouch
node: this will have my the ip address of where the application is?
application: name of the application?
topic: what do i put here?
Intouch v9.5
The application name for wonderware is VIEW. Topicname is TAGNAME. The node should be the computer name on the network.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
172
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
173
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
439
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
207
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
493
