Wonderware InTouch Custom Properties
ofiris
Jan 2014
IL
I have an ArchestrA object with many Custom Properties.
I would like to change the default values, there are over 300.
Is it possible to batch change these properties ? are these defined in a database / file which I can edit ?
Thanks:p
Have you tried exporting the object to see what that gives you for editing?
300 properties is a lot, sounds like the object should be re-created..
Why do 300 of them need to be changed??
I have an object which has many items embedded in it.
It is belongs to a power plant HMI and I need to simulate the tags, in real mode the tags are being read from the galaxy which reads them from the actual sensors / PLCs etc..
I need to simulate the process, therefore I want to change the custom properties to point to in Memory tags and change them programmably.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
173
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
175
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
446
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
210
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
495
