Wonderware InTouch Evet logging
Apollas
Nov 2013
city
22
Hello,
I'd like to do an event logging possibility in InTouch.
I need it for logging operator actions when one or another button was pressed and etc.
I'm planning to implement the InTouch alarm logic with different priorities; lowest priority alarm = event. Later on you can view and filter with the standard in-built AlarmDBViewer. The thing is that I'll have to ack every single event as an alarm and I cannot disable acknowledgements in general, because it's needed for real alarms.
Maybe there is a better way to do it?
Regards,
Giedrius K.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
158
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
411
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
187
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
481
