Wonderware intouch multiscreen - 3monitors
nirmalrb1992
Apr 2019
Georgia
Hi, Im trying to connect the 3rd monitor to the current system. how to code in quick functions for 3rd monitors. planning to use the wonderware application individually on each screens. Please, help. Thank You
Surely for 3 screens with independent control you need client licenses for each machine. Long time since I used Wonderware but I assume this is what you mean, In something like IFIX you have one database in the master and the clients point to it.
For multiple screens I have used the "ShowTopLeftAt()" function.
ex: ShowTopLeftAt (windowname, 1920, 0)
This will open the window in the upper left corner of the 2nd monitor (assuming your application covers both monitors). Never tried it with 3 monitors, but it should work the same.
This is a 1 operator station, 1 application setup. I'm not sure what you mean by "planning to use the wonderware application individually on each screens".
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
165
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
418
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
191
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
484
