Wonderware Intouch Time Stamp
barney123
Jul 2010
Mallow
Hi.. I was looking for a bit of help from someone that works with intouch scada... At the moment I have a Box that contains an animated Tick when a wash is complete.. This reads a Plc point ( wash01.01 ) From the plc and once the wash is complete point comes live and my Tick Appears on the Scada,Which is easy control.
What I am looking to do is instead of a tick is to have a timestamp instead..
1)Is there a small script that if a scada point comes live that I can populate a dialogue box with a time stamp..
2)There are 160 washes,, I know that I can generate a Time stamp using an intiger in the code for each of the 160 washes in the form of (2206011102 eg 11:02 on the 01062022) and one shot it each time to the scada.. But I was woundering if someone had found an easy way to do a simple memory timestamp
3) I know I could use the evet manager to display the event of the wash end, but for operators I know that I will get complaints that it is complicated,, Just a simple screen with the 160 washes and when they were completed time stamp instead of a tick..
Wonderware Intouch v10.0
Allen Bradley ( logix 5000) Plc
Any Help or ideas would be greatly appreciated
John
InTouch tags have .dotfield sub-attributes if you wanted to use that. When the tick value changes, it should get a current timestamp in a dotfield. There are various formats:
TickTagName.TimeDate
or
.TimeDateString
.TimeDateTime
.TimeDay
.TimeHour
.TimeMinute
.TimeMonth
.TimeMsec
.TimeSecond
.TimeTime
.TimeTimeString
.TimeYear
Ynpmoose,,
Thank you so much for your reply below... Took me a an hour to figure it out, but it is a great stamping system. Really do appreciate you sharing your knowledge.
I must do a bit of tweeking on my tags as they are I/O Integers..
My PLC Code is in the DINT format with the 32 Bits
My Intouch Tag is Wash,, But being that I am using the 32bit setup
my string is actually (Wash.01.TimeDateString) but this is not being accepted,,
I also tried (Wash.01 = 1.TimeDateString) but unfortunately this too failed to be accepted..
But overall a great outcome..
Thanks so much Ynpmoose for your help.. Back on Wednesday so hoping to put the project to bed..
Regards
John
Ynpmoose,,
Many Thanks,, Just Finished The extra Bool Tags sorted the issue.. Beats having to do this in the plc...
Just to say thanks for your knowledge
barney
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
156
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
166
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
428
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
195
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
490
