Wonderware Intouch to Janitza MODBUS
KIPeet
Sep 2008
Russia
Hi all,
How to define item name in Wonderware Intouch to read data from Janitza UMG503 power meter? I use IO Server Modbus. For example address 8000 in UMG503, I use item 'i8000' or 'r8000' or '8000 F' or '8000 S'. It does not work.
How to configure that item.
Thank you
Peet
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
157
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
167
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
428
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
196
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
490
