Wonderware Intouch troubles. No so wonderful.
Where are you going to set the Access Name in Intouch?
I cannot find the setting anywhere.
It's found in WindowMaker. Go to the Special Menu, then select "Access Names"; it's about six choices down, right below the Tagname Dictionary. A popup will come up; if you're creating a new Access Name, click the "add" button. Then fill out info from there.
When you create a tag that's an I/O tag, you'll be asked what Access Name the tag comes from. Then you need to provide the tag's address; in the case of Modbus, it'll be the register's address (40035 for a holding register, for example).
I would suggest starting with a single discrete bit and make sure that is working. Then, go to an INT and then finally, a REAL.
If you're trying to access a REAL, you'll need to add 'F' to the end of the address so tell InTouch that it needs to grab the consecutive address for the full 32 bits, otherwise you'll have REALLY bizarre looking data.
Hope this works!
I figured it out. Thank you so much for the help.
I was attempting to connect through the remote management settings which was incorrect. Instead, I needed to just connect at run time using the MOTCP driver and the Station ID: <IP address>:502, along with the correct I/O Address for whichever coil I wanted to assign a tag to.
209
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
200
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
504
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
224
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
507
