Wonderware InTouch10 - Calculating average temperature
Missy5
Jul 2008
NG
24
Can someone help me please? I have two temperatures and I'd like to calculate the average temperature. Average temperature must be written in output field.
I have two tags; booths are Type I/O Real and one tag Average, I defined it like Memory Real.
Then I defined Data Change Script like this
(Average )
Average = ((Temp1 + Temp2) /2);
I tested it but doesn’t seems to be working (I placed on my window two inputs for Temp1 and Temp2 and one output for tag Average – but nothing happens when I enter numbers into those two inputs).
Very interesting for me is that when I change output of tag Average to input and I enter for example number 30 for Temp1 and number 40 for Temp2, nothing happens yet. But when I enter one number into input of tag Average the right result pops out (35)!??
Thanks.
What you wrote is a bit confusing but your data change script will only execute when Average changes. Average will not change unless the script executes so it will never execute. Put your calculation in another type of script or use another trigger such as $Second changing as the trigger.
Your script is fine but it should be placed in Data Change Scripts for 'Temp1' and 'Temp2' instead of for 'Average'
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
178
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
117
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
207
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
197
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
178
