rrangaprasad
- Join Date
- Feb 2005
- Posts
- 28
Hello All
I've posted my question on various wonderware specific forums with no luck. Thats why i'm posing this here.
We want to install InTouch 2012 on Windows server 2008 standard 32-bit SP2
- The main problem we are having is that, when we run the setup.exe from the InTocuh 2012 DVD, nothing happens. No error messages. No errors in any of the event logs in the windows event viewer.
- There is another exe called prerequisites.exe in the same folder and that works fine. (it tells us we have met all the prereq)
- We installed InTouch 10.1. SP3 in the same machine with no issues (we did this just to check the install of InTouch in general)
- The same InTouch 2012 DVD works fine in a different machine.
- Also, wiping the Server 2008 machine and re-installing is not an option, as there are other programs/databases that re currently running on it.
- The server machine has SQl server installed on it and running.
So far we've tried the following with no luck.
1. doing chkdsk
2. Copying the files to local mahine from DVD and running it
3. uninstall and re-intall .net 3.5
4. went to msconfig and stop all non-windows services and re-boot and after that tryied to run setup.exe
5. right click setup.exe and run as administrator (we are also logged in as system admin)
6. try to run setup.exe in compatability mode for server2003 and xp
7. In "Progfiles\commin files\archestra\install" folder, there are log files. The log file goes through some steps and stops. The last sentence is "Getmaintenancemode".
8. When we tried to run setup.exe from a different machine, as soon as a window pops up to continue product or role based setup, we looked in the inatsll log and found that the sentence following the "Getmaintenancemode" is regards to "getlocalefilespath()" and that the files path is the location of the Intouch DVD. Also as soon as you cancel the installation in this machine, all the whole install folder disappears. However in the server machine, the install folder is still there with some log files. So maybe
(a) the setup still thinks that it is running and it is frozen at a state (which multiple re-booting is not fixing)
(b) Maybe its not finding the path using "getlocalefilespath()"
I appreciate any help in this.
1. doing chkdsk
