WonderWare Issue
Jmeadows7676
Oct 2013
Alabama
158
I'm currently trying to convert a wonderware intouch app 9.5 to 10.1 to move to a windows 7 PC from Windows XP.
When i Convert the Application it stops with the Error ("Cannot find DLL: "WCCHART""). Has anyone ever ran into this before. I'm Stuck.
Please Help
I don't recognize the DLL name but this will be a 3rd party or Wonderware add-in control. Try searching the old PC for that DLL, you may be able to copy it over and register it.
Even better would be to find the original installer package. If you have a support agreement you should be able to access the Wonderware support website (Aveva) and search there.
Alternatively if that control isn't being used, you can delete it from the project before converting, assuming you have WindowMaker 9.5 still.
"1)EventTrend–Copy the wcchart.dll and wcchart.wdo files into the InTouch folder (C:\ProgramFiles\Wonderware\InTouch)"
This was from an update from InTouch 7.11 to InTouch 8.0. It may work for you.
Just a thought.
Regards,
That did it.
I was able to get it from the original HMI computer in InTouch Dir.
On a side note there is a Access Name that is using OSRVPOLL.exe in SMC. Ive tried searching around on Internet and can't find a lot of information.
Anyone ever used OSRVPOLL.exe?
That did it.
Just googled...."OSRVPOLL".
OmniServer by Software Toolbox...OPC Server
https://www.google.com/search?rlz=1C2CHBF_enUS840SG842&biw=1536&bih=780&ei=QnI_Xa6VMoXf-gS15I-wAg&q=OSRVPOLL&oq=OSRVPOLL&gs_l=psy-ab.12..0i13l10.147678886.147678886..147681840...0.0..0.112.112.0j1......0....2j1..gws-wiz.........12%3A0j13%3A0.QpVg99Lk27Y&ved=0ahUKEwiuvvDpldvjAhWFr54KHTXyAyYQ4dUDCAo
Or...
https://www.softwaretoolbox.com/omniserver/staging/html/why_omniserver.html
Hi all, I am currently attempting to program an HOA system in Wonderware to communicate with a SLC 5/05. I have manually toggled the HOA logic...
358
Hello All, I'm having a weird issue with wonderware and don't know what I'm doing wrong. I upgraded my processors to L81 and wonderware to 2014R2...
2,747
Hi all. I have 3 computers using Intouch 2014R2. I just copy aaPKG back up from engineer console and import to other operator consoles. I met some...
1,266
We have two workstations each running a Wonderware view application and each with an access name to get tags from the other. We recently upgraded...
2,630
Wonderware Intouch, Kepware timing issue with "simultaneous" writing of many tags I have an Intouch application coupled with Kepware that is...
17
7,220
