Wonderware "Item" tagging for SLC500 tags
remullis
Oct 2012
Georgia
179
I am needing to add some tags in WW and I am new on creating tags within the
"Item" for SLC50). Example, I am looking at a address N17:12/5 and in WW it is pointed to N17:172/05. Looks like I need to use another format for my new addressing. If it is a binary conversion or octal is there a conversion chart, etc.
REM
Sounds like the bits in the word N17:12 are being used in the program logic and then being buffered in N17:172 to prevent asynchronous updates for the HMI display.
The item names in WW should be the same as in the SLC. There is no conversion required.
I thought they should be the same I simulated this with a new tag and had no problem.
I cant see any information written to the odd tag numbers and they all show unused. I will just create them as I normally would.
RM
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
102
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
183
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
180
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
165
