Wonderware licensing
phuz
Jun 2008
Mohnton, PA
1,044
In all the years of dealing with Wonderware, this never popped up.
What are each of the three numbers that are spec'd inside of a license file? I just order a license based on tag count and don't think twice about the contents of the file.
ie, #Dev Studio 2014R2 Large 5000 / 3000 / 500
Hi phuz,
Those numbers have to do with what the Development Studio is licensed to develop/test at for each product type, based on how you are designing your system.
So with 5000 / 3000 / 500 as an example, it would break down like:
5000 - The max number of external IO points from PLCs or other devices you can use to develop under the System Platform architecture. (Different than InTouch HMI tag development)
3000 - The max number of Tags, you can use to develop under the InTouch HMI architecture. (Different than System Platform object development)
500 - The max number of Tags that the included 24-hour Historian supports for testing the application you design.​
Dev Studios are meant to be used for development, hence they have some development use restrictions that normal runtime or user licenses do not have.
Regards,
I was recently called to a customer's plant where a roof had leaked all over their two Wonderware production computers. We managed to save them...
2,838
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
102
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
183
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
180
