Wonderware parse text to object
tisbris
Nov 2009
Greve
Basic info:
Wonderware System Platform 2014
Archestra Workflow
External system, Alarm generated Text file With fixed delimiter
I need some advice on how I Can trigger a workflow based on text in a text file.
This text file is generated by an old system and one text file contains one alarm - and the text file needs to be deleted before a new alarm text file is generated.
I am new to wonderware system platform so i dont know how this text file Can be transformed to an alarm in wonderware.
Solition one:
I am thinking that this text file could be parsed to a sql dB and Then a trigger could Update an archestra object which Then trigger a workflow.
Solution Two:
A script in wonderware is Reading this text file and somehow updates an object which Then is trigger a workflow.
Are these solutions possible or do one of you have another solution.
Any help is welcome.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
102
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
183
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
180
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
165
