wonderware question about access names
diat150
Mar 2006
Louisiana
1,475
I was just wondering if anyone has a better way to change the access name for a large set of tags (and devices for that matter) while windowviewer is running other than using:
IOSetItem
basically what I have is 1 big app in my office that polls a bunch of field devices, and I also have 3 polling apps out in the field that poll devices local to their field. I have the polling app in my office using view to bring the data back from the field polling apps here. In case of a failure of one of my polling apps in the field, I would like to be able to reroute all of my devices into my main app in the office.
as of right now the only way I see to swap the access names from the tags that I receive from the polling apps is to use this IOSetItem. Im all ears if someone has something simpler than making a mega script to handle all of these tags and wear out my fingers in the process.
sorry, I had a brain ****, this is going to be alot more difficult than I was thinking before I looked at it.
my issue is alot harder than I was thinking, not only would I have to change the accessname for the tags, but I would have to change the item name also, which I am not sure if I can do while windowviewer is running since i have item name = tagname checked.
it may be easier to just build a separate app for what I want to do... hmmm
So OfficeApp polls App1/App2/App3?
App1/App2/App3 have local IO servers that report back to OfficeApp?
OfficeApp can also poll the IOServers at App1/App2/App3 if required?
Can you not set the failover in the accessname config?
I have to work on a Wonderware HMI and have very little experience with it. The basic idea is to copy an old project, make a few edits, and load...
4,938
Im using Wonderware Intouch machine edition v8.0. Question: How does the Math Worksheet/Task scripting work? I have the following expression...
2,261
Hello all, I'm using WonderWare Intouch at my factory for the HMI. Here is what I'm trying to accomplish: Save data values (27 of them) into one...
21
7,575
Hi Guy 1. Please how can I create a shutdown button on the intouch? 2. Also how can I configure graphical Trend for 9 different values/tags in it?
2,791
Is Inbatch basically programmed similar to a PLC, it then reads/writes to a dumbed down PLC, which then performs the outputs? I'm having trouble...
3,248
